Power Windows only work from master driver switch
Old Apr 12, 2009 | 09:33 AM
FX4SCrew05's Avatar
Checked the passenger side door. No power at all! Looks like I might have a broken wire...Next time I get a chance I will start between the drivers door and A pillar...
Old Apr 13, 2009 | 06:35 PM
FX4SCrew05's Avatar
The child lock wire was broken in the driver door jam. Looks like 4-5 other wires are starting to crack also. I guess they used brittle cheap wires that crack and break when flexed a bunch of times?? I will have to fix the rest when I get around to it, or when something else breaks!
Old May 24, 2016 | 07:43 PM
Blackspots's Avatar
I just had to deal with this problem. A 10ga yellow with blue stripe and brown wire with blue stripe were broken.
Bought a new master switch thinking it was that, it wasn't. Tried fixing one of the passenger switches, that didn't fix it (in fact, I screwed up putting it back together the first time causing it to short). Had to cut off the rubber wire cover to look at the wires, and saw the two broke ones and fixed them. Finally fixed that switch and now everything works properly.
Oh, and sorry for necroposting.
