OBD2 scanner
Old Mar 17, 2009 | 12:11 AM
curtis73's Avatar
OBD2 scanner
I need a scanner. I now have three OBD2 cars, two of which are sick. I'd like to get something with real time data instead of just the single code display model.
I don't think I'll use it heavily, so I don't need the $2000 Snap On setup, I was thinking more like the cheapy versions.
Things to look for? I found a few on Ebay for $70 that read all five protocols including CAN for 2007-up vehicles, and its updatable.
Take a look and tell me what you think.
http://cgi.ebay.com/ebaymotors/SUPER...1%7C240%3A1309
Old Mar 17, 2009 | 12:52 AM
SSCULLY's Avatar
That one looks good, but it does not say which manufactures specific code it reads.
These can vary per mfgr.
I have the AutoTap one, with a few mfgr specific plug modules.
The nice part is the data logging feature. The bad part is it requires a laptop to run it on.
Old Mar 17, 2009 | 01:27 AM
IR0NS1N's Avatar
This is what I have at work.
http://www.actron.com/product_detail.php?pid=16298
It can be found for around 70-80 bucks, its pretty sweet, tells you what monitors are set, and Check engine light codes. Comes with a CD that tells you what each code means.
Old Mar 17, 2009 | 02:21 AM
curtis73's Avatar
It says that it has all current codes for mfrs up through 2008. The CD comes with all the codes. If I step up to the next model it comes with a USB and I can update it from my PC.
Old Mar 21, 2009 | 06:26 PM
Revenuer's Avatar
I use autoenginuity software. It hooks up to a PDA, or PC and gives you pretty much everything OBDII provides. It is pretty slick. Their website is www.autoenginuity.com.
I do not work for autoenginuity, I am just a satisfied customer.
John
