Door pad entry system question?
Old Mar 15, 2009 | 04:18 PM
20Screw01's Avatar
Did for put all the wiring in place for the door key code entry system on all f150's? Basically I just want to go to the junk yard and get the harness and entry pad and see if it will be plug and play with my truck that does not have it right now?
Thanks Dave.....
Old Mar 16, 2009 | 12:08 AM
SSCULLY's Avatar
Got a model year and trim level for that question ? ( or complete your profile ).
Old Mar 16, 2009 | 12:11 AM
20Screw01's Avatar
Year is in the profile and its a base level supercrew. (not xlt or lariat)
Old Mar 16, 2009 | 12:40 AM
SSCULLY's Avatar
Your profile is blank ( look to the right by the post count on mine and yorus, you have no truck info filled out ).
I did look at your profile to 2x check, you have the info in the signature ( I have them turned off ).
If you take off the door panel, and look for the keypad plug, you should see it through the speaker opening. Take a look at my interior album, I have the pictures from my 2001 XLT SCrew install. Don't know if this will be there on the XL trim level
Good luck
Old Mar 16, 2009 | 02:57 AM
20Screw01's Avatar
Got it thanks. Cant find your interior album though?
Old Mar 16, 2009 | 03:16 AM
GreenBuck50's Avatar
Your truck has to have a trim level... I am betting XLT. They did not have XL Supercrews that model year.
Old Mar 16, 2009 | 07:43 AM
SSCULLY's Avatar
Here is the link to the interior album ( get to it via clicking on the name, view public profile, then on the right is 2 of the xx albums, click the show all albums URL )
https://www.f150online.com/forums/me...rior-pics.html
This green terminating plug is what you are looking for
If you need some help with the door panel removal, download the directions for the Muth Signal mirrors ( www.muthco.com )
I m going to have to defer to GreenBuck50 on if there was a XL trim level that year, I didn't look, so I cannot recall.
Old Mar 16, 2009 | 05:18 PM
20Screw01's Avatar
Looks good thanks!
Old Mar 17, 2009 | 03:28 AM
I believe my model year... 2008... was the first year for the XL Supercrew... in 2001 the only trims for Supercrew were XLT, Lariat, King Ranch, and Harley.
Old Mar 17, 2009 | 12:20 PM
20Screw01's Avatar
I guess mine is an xlt then but it does not say it anywhere? Wierd , also is the green side of that plug go to the door pad and is the other gray side go to the truck?
Old Mar 17, 2009 | 12:42 PM
SSCULLY's Avatar
If the front badges have not been acetone'd, it should say under the F150 logo on the front fender
The green plug is coming from the truck's harness, the gray side in that picture, is a terminating plug that is installed, when the keypad is not there.
Did you take your door panel off yet ? It is a 5 min job to pull it, and the speaker, and take a quick look, it should be right there. The picture above is where it was when I pulled my door panel, and speaker out.
Old Mar 17, 2009 | 12:51 PM
20Screw01's Avatar
That why it not there they have been acetoned. Taking it off today to take a peak... let ya know what I find...thanks again.
