Trailer Brake Wiring
Old Mar 8, 2009 | 06:48 AM
BOWERSdaAZIAN's Avatar
Hey guys, i just purchased an 18' open bed car hauler. It came with a 6-pin round connector, however obviously all tow package F-150's come with the 7-pin blade receptacle (like my 1999 SCab 4x2 5.4). I went out to the local tractor supply and found an adapter to switch it over, however the brakes do not function.
like this
Now ive been reading that these adapters may need to be rewired for different brake wiring configurations. My box said "It comes with the brakes wired to the parameter accessory pin." and it can be easily changed by opening it up and swapping the lead connections.
My ultimate question is what pin on the truck side correlates to the brakes?
I can figure out which wire on the trailer does it, but still need to know on the truck side so i dont cross the wrong wires.
Alan
Old Mar 8, 2009 | 08:05 AM
WildmanNP's Avatar
It's the blue wire on pin 2 next to the offset,I can email you a pic if you want it.
Old Mar 8, 2009 | 11:33 AM
SSCULLY's Avatar
Page from the Trailer Tow install directions
Old Mar 8, 2009 | 04:59 PM
Thanks!
I could not find any posts in regards to this, where is this 'Trailer Tow install directions' post? i think it may come in handy.
Ill have to check out my trailers wiring setup and open up the adapter to get a clear understanding of what im dealing with. Hopefully all goes well.
Thanks again guys
Old Mar 8, 2009 | 06:54 PM
SSCULLY's Avatar
It is not a thread, the directions come with the trailer tow package from teh factory.
If you are not the original owner, drop me an email via my profile and I will email you the PDF scan of the directions.
Some good info in the towing and hauling forum as well
https://www.f150online.com/forums/towing-hauling-72/
Old Mar 9, 2009 | 12:16 AM
Good to know. I think i have some info from the original owner.
And the brakes have been 'fixed'. Just had to swap the center pin over to the pin described above and all is well. Prodigy is handling everything great.
Thanks again guys!
