Reverse light...help!!!
Old Feb 15, 2009 | 08:12 PM
MM(SS)Wissinger's Avatar
I have a 1994 F150 and apparently the last owner had to do some shady wiring jobs for the tail lights. It looks like they made their own version of a trailer hook-up, but the problem is now that I have it, my reverse lights don't work...at all. I also have found out that the third brake light and associated bed lights are missing...completely. I have the little cover that goes on it, but no bulbs, etc. Since I am not made of money and it is only my work truck, I was hoping someone could give me a little insight as to how to make these work so that I can pass state inspection. I can do the work myself, and as i said before, am not made of money so would like to try to just do some quick fixes that will work. I thought there might be a relay somewhere in the cab on the power wire for it, but have no clue where to even start looking. Anyone able to help??
Old Feb 15, 2009 | 08:19 PM
kcsboys's Avatar
try this site.....it might help
http://www.wirediagram.com/ford.htm
Old Feb 16, 2009 | 08:08 AM
SSCULLY's Avatar
Did you check the fuse for the reverse lamp circuit ?
The CHMSL, you will need to purchase the bulb holders ( bone yard, or dealer / online dealer maybe a parts shop would have the same twist in socket types ? )
Old Feb 16, 2009 | 07:32 PM
Ok, I am not to savy with electrical stuff, so a couple of questions:
1) Where is the fuse for the reverse lamp circuit?
2) What is CHMSL, is that the third brake light?
Old Feb 17, 2009 | 06:00 AM
02SC4x4's Avatar
1. check in your owners manual. (the ford site only goes back to 1996, at least that i can find)
2. yes, Center High Mount Stop Light?
