97 F150, Viper 5301 programming problem
Old Feb 10, 2009 | 03:16 PM
twheeler's Avatar
I can’t seem to get my system's learn routine to change a setting. By default, the unit is set to manual transmission mode, but I have an automatic. Here’s what I’ve been doing…
1. Inside the vehicle with the door closed.
2. Turn IGN on and off.
3. Press and hold program button until LED flashes 3 times.
4. At this point I release the program button, and the LED flashes three times.
5. Press and release the program button once, then press and hold, the LED flashes 1 time.
6. Still holding the program button, hit the unlock button on the remote, the LED flashes 2 times.
7. Release the valet button, turn IGN on and off.
8. Get out of vehicle, close door, press RS button on remote.
9. I get an error tone and the parking lights flash 7 times.
Any idea why my change won’t stick?
Additional info if it helps...
Harness 1, 3, and RS Input are connected as indicated below. Aux, RS Output, and Door Harness are not connected.
Harness 1
Pin 1, red/white, trunk release not used.
Pin 2, red, +12 constant connected.
Pin 3, brown, horn output not used.
Pin 4, white/brown, light flash isolation not used.
Pin 5, black, grounded.
Pin 6, violet, + door trigger input not used.
Pin 7, blue, horn input not used.
Pin 8, green, - door trigger input connected.
Pin 9, black/white, dome light output not used.
Pin 10, white/blue, remote start activation not used.
Pin 11, white, + parking light output connected.
Pin 12, orange, ground when armed output not used.
Harness 3
Pin 1, pink, connected to blue/green ign wire.
Pin 2, red/white, connected to yellow +12 constant.
Pin 3, orange, connected to gray/yellow acc wire.
Pin 4, violet, connected to red/blue starter wire.
Pin 5, red, connected to yellow +12 constant.
Pin 6, pink/white, connected to red/black ign 2 wire.
Pin 7, pink/black, not used.
Pin 8, red/black, connected to yellow +12 constant.
RS Input Harness
Pin 1, black/white, neutral safety wire grounded.
Pin 2, violet/white, tach input not used.
Pin 3, brown, brake shutdown input not used (yet.)
Pin 4, gray, not connected.
Pin 5, blue/white, second status not used.
