Reparing Lighted Switches
Old Feb 4, 2009 | 06:11 PM
JackandJanet's Avatar
Like many of you, I became frustrated when I discovered that the two power window switches on the passenger side, and the two door lock switches in the front were no longer lighting up. There were posts on replacing LEDs in earlier switches, but nothing about repairing ones in 2004-2008 trucks. I decided to give it a try.
First, you have to get the armrest switch plate off the door. It's easily pried off with a plastic putty knife (if you don't have a trim tool). Disconnect the electrical connectors and remove the switch from the plate - the procedure should be obvious, once you look at what you have to do.
Next, pry the switch rocker cover off the switch. I used a flat-blade screwdriver to do this. Here's what you see now:
The LEDs shine up through the translucent membrane around the white switch rocker (when they're working, that is).
Now, you'll have to get the black top off the switch housing. I used a flat blade screwdriver to spread the sides of the housing enough to release it. The white rocker, sitting above the circuit board, is exposed now and comes out next.
Just pull the sides away from the white rocker ( used my thumbnail) and it will slide out. Now you can see the switch armatures themselves, down on either side of the circuit board pointed to by arrows. I just lifted these out with tweezers. The LEDs are circled and they are TINY - about 1 mm.
Now you have to get the circuit board out of the switch housing. I used a large, flat-bladed screwdriver to pry it up off the three supports that hold it on. At this point, here's what you have:
I found the switch contacts were "blackened", probably from arcing, so I burnished them with a typewriter eraser.
Here's a closer look at the underside of the circuit board. I found cracks in the circuit on one or both sides of the 431 ohm resistor in the location pointed to by arrows. They were visible with a 10-power magnifier. The LEDs are wired in series with this resister, so if there's a crack in this circuit, neither LED will light.
I repaired these cracks with a small piece of #26 copper wire soldered over the crack to bridge it.
Another weakness in the design are the circled rectangular areas. They have to make GOOD mechanical contact with the supports holding the board to the switch housing, because that's the electrical supply.
Once I made the repairs and checked for continuity with an ohmmeter, I reassembled the circuit board onto the switch housing. The circled tabs are what hold the board in place and they have to do it tightly, or you won't get an electrical feed. I used a nail set tapped lightly with a hammer to spread them and hold the board down securely.
I actually considered soldering the board to the supports, but decided against it in case I ever needed to remove the board again.
Finally, we can test the switch in the truck. Thankfully, it can be done as soon as the board is back in place by simply plugging it in to the wire harness as you see here:
With the ignition ON, the LEDs are lit up! I also tried "wiggling" the board on the switch and found I had to tighten two of them down better with more taps from a nail set. I was glad I tested the switch before completely reassembling it!
The rest of the reassembly was the reverse of the disassembly. The door lock switches are quite similar to the window switches, but not quite as complicated.
The whole process took about 2-3 hours to do and now my switches are all lit again.
- Jack
Old Feb 4, 2009 | 06:52 PM
momalle1's Avatar
Nice how-to. Seems like a lot of work.
Old Feb 4, 2009 | 06:53 PM
james-06scl's Avatar
Wow, given our "throw away society", many would have replaced them. Good job getting them working again. Great write up, pics, and explanation too...
Going to bookmark this one, Thanks!
Old Feb 4, 2009 | 10:25 PM
Thank you, gentlemen! It wasn't that much work, once I figured out the problem. I found that the door lock switches run about $20 apiece. I haven't found a price for the window switches, but they are more complicated and must cost more.
And - I'd be afraid of getting some with the same defects. I feel pretty confident in my repair. We'll see how it holds up.
- Jack
Old Feb 5, 2009 | 08:29 AM
jbrew's Avatar
So this is what your talkin about. I have to see if mine light up now - I don't know ? Looks easy enough, now I'm curious.
Nice Job Jack.
Old Feb 5, 2009 | 12:18 PM
SSCULLY's Avatar
- Jack
Jack,
I had to replace my master power window switch on my 2006 already ( water from snow falling in on it ) and it was $ 38.04 from www.oemfordparts.com when I ordered it ( p/n : 5L1Z-14529-AA ). Add to this 9.50 in S/H.
I just took apart my old one to take some quick pictures of it.
the LED board is soldered onto the housing, rather then the type that you show on the power door lock. Bit different layout, but the same design.
Red circle is the solder joints for powering the LEDS, and the LEDs are circled in blue.
Thanks for starting this thread, might want to have RP make it a sticky at the top.
Old Feb 5, 2009 | 04:24 PM
Thanks for the link, SSCULLY, and thanks for the part number. That unit is a lot cheaper than I thought it would be!
You may want to correct your description to say the LEDs are circled in blue, but it's a great picture. Bummer, in a way that the board is soldered to the switch housing, but I bet that removes one of the weaknesses in the design of my switches. However, if any of the circuits develop hairline fractures, good luck on getting in there to fix them!
I didn't take my master switch out, since all the LEDs in it are working. I wonder if it's the same design as yours?
- Jack
Old Feb 5, 2009 | 05:57 PM
SSCULLY's Avatar
..<snip>...Bummer, in a way that the board is soldered to the switch housing, but I bet that removes one of the weaknesses in the design of my switches. However, if any of the circuits develop hairline fractures, good luck on getting in there to fix them! ..<snip>...
Good part is, the resistors and all the solder work is on the side facing up of the circuit board. The back has nothing showing on it, not even a trace. Hold the edge up to the light, seems to be a single layer board.
There are even test points in the traces, about the size of a meter probe.
This one, no need to take it out, but I guess if you wanted to, some solder rope and a good iron, it would be out in 2 min flat.
You can see the same discoloration on the switch contacts, that your power lock has in this close up as well.
Quick test on this one is + and gnd to the 2 solder points, and all the lights should light. The test points would give you the ability to find the problem path to fix it, if the need ever arises.
Thanks for pointing that out, got the text correct.
Old Feb 5, 2009 | 08:06 PM
Excellent addition, Sir, as always! Nice to know the circuits are all on the "exposed" side. Now I don't have to worry about problems with that unit.
Interestingly, I went to the link you gave (which is Southwest Ford) and I simply cannot find the switch. With the part number you listed, I found it in two or three other sources, but at a higher price - $46-$49 as I recall.
Just looking at the new picture you posted, since there are four pairs of LEDs, it looks like they may ALL be wired in series, eliminating the need for a voltage dropping resistor, and, if they ALL go out, you know what the problem is!
I PM'd Rockpick about a sticky status too, thanks for the suggestion.
Old Feb 5, 2009 | 08:19 PM
j2h1's Avatar
Kudos! good work, I noticed last summer when I took my swiches out, the solder looked shoddy. I will have to fix all but the master including the rear window switch now that I only work 30hr weeks and bordom is setting in.
Old Feb 5, 2009 | 08:29 PM
Rockpick's Avatar
Moderator &
Jack - Excellent post, sir. Thanks for the contribution to the site.
Rather than sticky'ing it within the electrical forum, I'm going to utilize our 'How-To' forum for this post...
It's my hope that we can continually build the How-To forum with EXCELLENT threads such as this one...
Naturally, I'll leave this one in-situ too...
Thanks again for your contribution!!!!
-RP-
Old Feb 6, 2009 | 02:22 AM
jbrew's Avatar
Well, mine light up. The power mirror switch does not. I couldn't tell if was suppose to or not. ? Seems like it should. ? I'll look into it.
Old Feb 6, 2009 | 06:15 AM
02SC4x4's Avatar
on my 04 the power mirror switch does not light up, but the lock and windows all do. i did my master switches and put 3mm LEDS in there and they fit with no clearance issues. i can add that the green LEDs i bought were a slighty different shade from the OEM and were a bit brighter so i ended up doing the whole truck so it all matches now.
i also managed to get lucky and come across a master switch when i was in a body shop one day and picked it up for free. they told me when i asked for it that the buttons/lights werent working, etc. little did they know that i only wanted the LED board out it because my first time doing it i managed to mangle the board pretty good. that hardest thing about the board for me was getting the main solder joints to make contact and stay that way.
all of the switches have a resistor to each pair of LEDs for that respective window. the exception is the driver window switch which has a resistor traced seperately to each LED. (i dont know why and both resistors are the same 431ohm as the rest of the switches) as i sit here and type this my driver window up LED is no longer lit up. and i reiterate that this is on a 04 and things could have changed by 05/06.
another FYI is that the resistors do crack away from the traces. while having it all apart you may want to resolder all the resistors.
SSCULLY - how did you mange to get water anywhere near the contacts or the circuit board? they seem to me to be designed so that everything overlaps and that the water would run off the switch button onto the main block, then down into the door.
Old Feb 6, 2009 | 10:37 AM
SSCULLY's Avatar
....<snip>...Interestingly, I went to the link you gave (which is Southwest Ford) and I simply cannot find the switch. With the part number you listed, I found it in two or three other sources, but at a higher price - $46-$49 as I recall.....<snip>...
The new Southwest Ford parts site is www.southwestfordparts.com
I took a look at my Rcpt, and the list price on the switch in JUN-07 was 6.00 lower then it is now, so the switch would be about 3.5 higher, depending on the raise in dealer's cost, so 42.00 to 44.00 is about right for the current switch costs.
I went back and looked, and they had changed the www.oemfordparts.com web site to be the Ford Racing catalog for some reason, but the link above is the direct URL to the Southwest Ford Trademotion site.
Old Feb 6, 2009 | 10:41 AM
SSCULLY's Avatar
Originally Posted by 02SC4x4
...<snip>....
Melting snow. Getting in and out of the truck in the winter, the door handle will get covered with snow. It is kind of hard to clean it all off after getting in, and when it melts, it is on the run to the switch opening. Same for rain I guess, it is is on the door handle itself ( not the switch tops ) it is making a run to the switch opening.
Those rubber dust covers don't stop water from getting in.
