Power window switch issue
Old Feb 1, 2009 | 10:23 PM
cherubrock74's Avatar
I searched the forum and I found out that many of us are having troubles with the power windows switches and lights...so that helped making me feel a little bit better
But I still want to fix the problem so here is what I have
front and back passenger windows go down only using their switches.
Windows will go up and down normally if I control them from my driver side switches.
When I inspected the front and back passenger switches it appears that only for the "working" side of switch you hear the "classic" click
On the opposite side, the one to roll the window back up, you do not hear that click...
should I just try to replace both the switches?
It seems it is not the power windows motor since I am still able to pull the window up and down from my drivers commands...
what is your opinion?
PS I will post a picture of my truck soon, as ATP requested
Old Feb 1, 2009 | 10:41 PM
SSCULLY's Avatar
While you were inspecting them, you should have tested them with a meter.
This would remove the parts swap diagnoses.
