'07 Reverse light hookup
Old Feb 1, 2009 | 12:12 PM
MN7thSon's Avatar
I received a PlasmaGlow Fire and Ice LED taillight bar bar as a gift and I need to splice into the reverse light circuit to make the white LED's work when I put the truck in reverse. I would like to know if someone could help me determine which is the appropriate wire to splice. The rest of the light bar utilizes a standard 4-wire trailer connector, but the reverse lights must be hard-wired.
Old Feb 1, 2009 | 02:47 PM
SSCULLY's Avatar
Do you have a 7 pin trailer plug on your truck.
This is the bet place to get the reverse circuit, as the truck's will not allow a 1 amp LED light to burn at full brightness with the factory lights installed.
Old Feb 1, 2009 | 06:00 PM
MN7thSon's Avatar
Thank you for the quick reply. Now it looks like I need only wait for the weather to warm just a bit.
