Heated seat conector?????
Old Jan 27, 2009 | 07:18 PM
twintips_17's Avatar
I’m doing a console swap from an expedition this week and I have been searching for posts about adding heated seats to see if my truck will have the connector. I found a thread about the seats from back in 06 and it had a lot of good info but on the second page of it Lightningcrew talks about 1st gen and 2nd gens not having the plug.
I would like to know if my truck with a build date of 06/02 (FX4 Supercrew) will have the connector.
If anyone has a post that they know of with more info that would be great.
Here is the post i was looking at.
https://www.f150online.com/forums/el...ted-seats.html
Old Jan 30, 2009 | 01:02 AM
Bumpski.....
Old Jan 30, 2009 | 10:26 AM
SSCULLY's Avatar
I don't know if your truck will have the connector or not, but your build date is a Gen III SCrew.
The GEN I & Gen II were in the first build year, 2001, and were done by early 2001. My 2001 SCrew was a GEN III, with a build date of 5/01.
Only way to verify that the connector is there, is to go take a look, that is what I had to do with mine when I added the Nav visors, and the door key pad.
Old Jan 30, 2009 | 11:46 AM
Where is the easiest place to look? I pulled the seat all the way forward and tried to find a hole in the carpet but couldn't. You didn't happen to take a picture of it did you?
Old Jan 30, 2009 | 12:24 PM
SSCULLY's Avatar
Didn't take a picture, but you need to look a more closely, you missed the hole through the carpet, where the seat belt wiring goes through at least.
Old Jan 30, 2009 | 01:11 PM
My 03 had manual seats, and only had the wiring for the seat belt reminder.....
Old Jan 30, 2009 | 03:19 PM
I found the hole. I was looking from the wrong side. I was looking from the back and its in the front. I couldn't pry the carpet up much, i didn't want to ripe it. I couldn't find the conector though. How far under the carpet would it be? Would i have to pull the carpet all out on that side to find out if i have it or not?
Old Jan 30, 2009 | 04:06 PM
So i think i got it figured out. I went and looked at the seats that im putting in and i have all the connectors that they do on both driver and passenger seats. Am i correct in saying that the same conector that powers the heat also powers the motors for the seats?
Old Jan 30, 2009 | 05:25 PM
probably one big connector for heat and motors, but i dont know for sure
