Remote starter install
Old Jan 1, 2009 | 04:18 PM
jutwan88's Avatar
I recieved a remote starter for christmas it is the ProStart 3in1. I installed it today and everything works perfectly, except when i push the lock/unlock buttons it only arms/disarms the vehicle but the power locks do not lock/unlock. I bought my truck used it is a 1998 F150 extended cab flareside XLT 4x4 5.4L is there something i have missed?
any help would be great thanks.
Old Jan 1, 2009 | 05:35 PM
rojoracing's Avatar
if i remember your door locks are 5 wires you must use a relay you can go to 12volt.com if you cant find it i will look and i can email you more info on how to do it i was a car audio installer for 8 years
Old Jan 1, 2009 | 05:42 PM
jutwan88's Avatar
wow really? the installation instructions just said to tap into pink/yellow wire for lock. and the pink/lt.blue for unlock so that is what i did. but if you have more info that'd be great.
Old Jan 1, 2009 | 05:52 PM
rojoracing's Avatar
its a 1998 two door right
Old Jan 1, 2009 | 06:03 PM
jutwan88's Avatar
3 door
Old Jan 1, 2009 | 09:55 PM
jutwan88's Avatar
anybody?
Old Jan 3, 2009 | 07:50 AM
jutwan88's Avatar
so i've wired everything as per the directions. could someone tell me how to get the locks to work? Do i have to go straight off the door lock motor because i went off the switch at the pink/yellow and pink/lt. blue but locks are not working. Is there more I should be hooking up? all help is appreciated.
Old Jan 3, 2009 | 09:07 AM
projectSHO89's Avatar
You need to determine wheter or not you have remote keyless or not.
The wiring is different for each.
Steve
Patience is a virtue to be practiced.
Old Jan 3, 2009 | 01:00 PM
jutwan88's Avatar
it says for remote keyless wires will be pink/yellow for lock and pink/lt. blue for unlock. I have located those and wired the lock and unlock wires to them and have not been able to get it to work.
Old Jan 3, 2009 | 01:04 PM
mattd17's Avatar
well a remote starter uses different wires to arm/disarm, and lock/unlock. this would tell me that you have the arm/disarm correct, but not the lock/unlock. have you verified the wires that you tapped into for the locks? actuate the locks by hand and verify that you have the correct wires first of all. next, is to make sure that you have the polarity correct. i have seen SEVERAL times where the instructions list the wrong polarity for different functions. depending on the features of the remote starter, you may be able to change an "onboard relay" jumper...... if it doensnt have them, you can add your own external relay. very easy to hook up though.
based on the fact that you went off the wires directly at the switch, i would assume that you just have the wrong polarity. try to run a jumper from a ground source to one of the lock wires..... just touching the jumper to the wire should activate the lock cycle. then do it on the other one too..... your locks should cycle when a ground is introduced.
then i would verify that the starter unit is putting out a ground to the lock/unlock wires when you push the buttons.
let us know what you find out. i absolutely love installing remote starters, but i have found that they sometime do require you to pick your brain apart and do some troubleshooting....thats the bad part to electronics..... you can always see whats wrong, so you have to get clever and find it!!!
good luck and let us know !
Old Jan 3, 2009 | 01:12 PM
mattd17's Avatar
ok, i just found another website which states that your wire codes should be:
lock: pink/yellow
unlock: pink/light green
this is just a little different, so check and see which one is correct.
Old Jan 3, 2009 | 02:19 PM
jutwan88's Avatar
ok. i'm hooked up to both those. but now i'm reading the install. instructions and there is also 2 wires i currently do not have hooked up. I'm not sure if this could be the problem i was told it isnot but here we go. the 2 wires that are not hooked up are a arm output and the description says 500mA ground output when the LOCK button is pressed. This output is activated 500ms before the LOCK pulse and deactivatd 250ms after the LOCK pulse ends. wire 2 is a Disarm negative output stating 500mA ground output when the UNLOCK button is pressed. SHould these 2 be connected somewhere? and if so where? sorry for the headaches everyone but the help is great
Old Jan 4, 2009 | 09:41 AM
jutwan88's Avatar
any ideas? does somebody have a wiring diagram for the power locks for a 1998 f150? that would be great. thanks.
Old Jan 5, 2009 | 10:13 AM
rojoracing's Avatar
Battery Constant 12v+ Positive Wire (+): Green/Purple or Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Red/Light Blue
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Blue/Green or Red/Green
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Red/Black
Second Ignition Positive Wire Location: Ignition Switch Harness
Third Ignition Positive Wire (+): Black/Green
Third Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Gray/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Tachometer Wire Negative Wire (-): Blue/Green
Tachometer Wire Negative Wire Location: Multi Coil or White/Pink PCM passenger side firewall.
Neutral Safety Wire: Not Grounding
Neutral Safety Wire Location: The OEM switch opens the starter circuit.
Brake Light Wire (+): Light Green
Brake Light Wire Location: Brake Switch
Trunk Pin Switch Negative Wire (-): N/A
Trunk Pin Switch Negative Wire Location: N/A
Parking Light Positive Wire (+): Brown
Parking Light Positive Wire Location: Behind the fuse panel in harness or driver’s kick panel.
Headlights Positive Wire (+): Red/Yellow (+)
Headlights Positive Wire Location: Light Switch
Factory Alarm Disarm Wire (-): Dark Green/Purple(-)
Factory Alarm Disarm Wire Location: Driver’s Kick Panel
Door Trigger Negative Wire (+): Black/Light Blue(+)
Door Trigger Negative Wire Location: Harness In Driver’s Kick Panel
Door Lock Wire: Pink/Yellow
Door Lock Wire Location: At passenger kick panel. Negative trigger if vehicle has keyless
entry.
Door Unlock Wire: Pink/Light Green
Door Unlock Wire Location: At passenger kick panel. Reverse the polarity if vehicle doesn’t have keyless entry.
Horn Negative Wire (-): Dark Blue (-)
Horn Negative Wire Location: Steering Column
Anti Theft Type: N/A
ECM Module Location: N/A
BCM
here is what us installers use when installing alarms or remote startes.
Old Jan 5, 2009 | 10:15 AM
rojoracing's Avatar
follow the door lock and unlock part should fix your problem
