aftermarket power windows
Old Dec 31, 2008 | 02:31 PM
vegas08f150's Avatar
i have a 2008 subecab stx that im gonna put power windows in. im gonna buy te motor/regulators directly from ford and am thinking of putting in these switches http://www.customstreetdesigns.com/162-33040147.htm. is there anything else i am missing or that should cover it. any input will help. esp from chris adams. thank you
Old Jan 1, 2009 | 11:32 PM
badassfx4's Avatar
Rather then getting the parts from ford go to this website, http://www.a1electric.com/electriclifewind.htm
I've installed a couple of kits from here, and have had absolutely no problems.They use all factory regulators and they are much cheeper than buying from ford directly.
Old Jan 6, 2009 | 04:23 AM
i havent seen them for my truck on there though. factory wants 150 a piece. which i dont think is too bad. i could be wrong
Old Jan 7, 2009 | 05:53 AM
bewtew's Avatar
check out f150partsguy.com. i believe the regulators go for 100 a piece and the shipping is quite reasonable.
as far as switches go, id check out this one:
http://www.a1electric.com/Merchant2/...de=4980-21-007
i've got them mounted where the cig lighter is. very easy to install.
Old Jan 7, 2009 | 06:55 AM
thank you. ill check them both out... do you happen to know the diameter of the hole where the crank went. i might put some tweeters in there. i would check myself but i am overseas in iraq right now. thanks for the input
