Bad power window switch???
Old Dec 26, 2008 | 06:27 PM
RI04F150's Avatar
I have an 04 FX4 and the other day my wife tried to put the passenger side window down, it started to go and then slowly stopped. I can operate it just fine from the drivers side, but the switch on the passengers side is in-op? Anyone else have this problem? I have heard about faulty motors problems but not switches..
Old Dec 26, 2008 | 07:13 PM
shorse's Avatar
a switch will either work or wont... it wont slow down...
bad motors... i dunno.. some one else can chime in
Old Dec 26, 2008 | 07:22 PM
JackandJanet's Avatar
You can easily have bad switches AND/OR bad motors, but, slowing down? That doesn't sound like a switch at all does it? And, if everything works fine from the other side, can't be a motor problem either.
I just recently took my "Door Lock/Unlock" switch off the passenger side to see if I could repair the fact that it no longer lights up at night. Short story here is no - those are the tiniest LEDs I've ever seen and there's no way, that I can see, to bypass them with others, or to repair their circuits). But, the contacts for the switch itself are easy enough to clean/burnish once you get the switch apart (which is a whole lot of fun too). Possibly some bulb grease on the contacts would prevent corrosion in the future?
- Jack
Old Dec 26, 2008 | 07:50 PM
RI04F150's Avatar
Well the switch only slowed for a brief moment when she pushed it and immediately died..Basically it started going down and then died..I took it off, jiggled the wires, re-plugged it in and still nothing!! But I agree, can't be the motor because the other switch works perfect! SOmebody help me out here
Old Dec 26, 2008 | 08:03 PM
shorse's Avatar
okay.. if it works on one switch... it is either the wires or the switch that is not working...
get a test light and one side of the switch MUST have power to work....
if not, check the wiring
Old Dec 26, 2008 | 08:15 PM
switch is probably bad
Old Dec 27, 2008 | 10:15 AM
SSCULLY's Avatar
It is a problem with the switch on the passenger side, considering the driver's side switch still operates the window as normal.
The wiring is power from the driver's side switch contacts ( for the right window ) to the passenger's side switch, to the motor. The power is in series to the passenger side.
This is a pure luck item, where the passenger side switch has failed to the normal position ( contacts are connected through ), usually when the passenger side switch fails, the window does not work from either side, causing the where waldo diagnoses ( both switches and the motor seem to be in question ).
Here is the diagram for a SCab / SCrew power window, so you can see what I am talking about with the series wiring.
My driver's side switch failed ~20 months in on my 2006, I am guessing from it getting wet. The window would be slow to move, and some times I had to really mash the switch to get it to go up, and the contacts were the issue, so the down was fine, the up would be slow, due to a poor electrical connection ( high resistance load, using part of the power to move the window ).
~ 52.00 to replace ( MSRP is 73.10 ) from www.oemfordparts.com
2004 F150 mechanical catalog
Electrical -> Body Electrical -> Door -> Interior Trim
