Reverse light issue?
Can someone give me hint off where my problem might be. I'm trying to put a white night reverse light system on my screw, but I have no power at the trailer plugin for reverse. I've checked all fuses I can find, but can't figure out why I have no reverse at the trailer connector.
I might add I have reverse lights just none at the trailer connection.
Thanks, Donnie
Thanks, Donnie
Which fuses id you check ( all is a stretch, you checked the fuel pump fuse in this process ? if so why ? )
#2, did you check if the trailer tow install was completed ? This includes the trailer tow reverse lamp relay.
The fuse for the trailer tow reverse lamps is Battery Junction box fuse #5, 20A
also in the battery junction box is the trailer tow reversing lamp relay.
last question, how are you testing that there is no reverse at the 7 pin adapter ? could be a 7 pin socket problem, depending on how often you use it. Best to use a meter to another ground, and test for the battery charging circuit, as a baseline.
