Battery change question
Old Dec 8, 2008 | 09:47 PM
Rainforestrider's Avatar
I need to change the battery on my 2001 5.4 Supercrew. First question-is this a basic job (the shop wants $42 labor) i.e undo the cables, battery clamped on the tray, easy to remove? Second question - is there any kind of computer reset associated with the change?
Old Dec 8, 2008 | 10:21 PM
The hardest part is lifting it out and setting the new one in. Really, it is very straight forward, takes maybe 10 minutes. No, nothing to reset except the clock and psooibly the radio buttons.
Old Dec 8, 2008 | 10:32 PM
shorse's Avatar
i did it today... backed up the 150 to the truck that needed the new batt, a f-350, and that made it so i didn't need a ladder to get high enough to pick it up easily... took off the bat clamp, 1/2" nut on the batt cables, take them off, and lift....
almost as easy as changing a wiper blade, just heavier...
Old Dec 9, 2008 | 08:00 PM
scotyg's Avatar
i did it within in 10 minutes, dont bother paying a shop. i cringed buying a $80 battery after id only had the truck a couple months
Old Dec 9, 2008 | 08:03 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
My radio presets held.
The clock went to 12:00, that's about it.
ps. DO NOT pay someone $42 to change your battery.
Advance Auto will install for free, they are nationwide, good battery selection.
Old Dec 12, 2008 | 04:15 PM
DaMoose81's Avatar
Iv edone everything from tire changes to engine rebuilds and its always taking me like an hour to change my wiper blades, i guess they are my kryptonite.
Old Dec 12, 2008 | 04:43 PM
Raoul's Avatar
25 Year Member
Originally Posted by DaMoose81
I've done everything from tire changes to engine rebuilds and its always taking me like an hour to change my wiper blades, i guess they are my kryptonite.
You are not alone.
I'm fairly handy but, I pretty much can't change wiper blades without making woman sounds.
Old Dec 12, 2008 | 05:15 PM
Originally Posted by Raoul
You are not alone.
I thought I was the only one! I think I'm going to break them before I figure them out. They're like some kind of puzzle.
Old Dec 12, 2008 | 07:12 PM
JackandJanet's Avatar
To continue this hijack: Why can't these flippin things be "standardized"? It's not like they're hi-tech or anything.
- Jack
Old Dec 15, 2008 | 01:00 AM
corvet3640's Avatar
First, try to do it yourself-Super easy, disconnect it (negitive first) remove the hold down (ask where it is if you don't see it at the shop) and pop that puppy out. If your unable for what ever reason-go definately go someplace like advance where they do it for free.
Second as far as windsheild wipers... I forget how to do it everytime I do it, in fact I don't even really know how I did it after I'm done-I just know I now have the old ones in my hands.
Old Dec 16, 2008 | 11:45 PM
Thanks for the replies, battery looks easy. As for the wipers I just bought some basic ones from Napa and they took me two minutes. Usually I go crazy trying to figure them out.
Old Dec 17, 2008 | 07:45 AM
Raoul's Avatar
25 Year Member
Thanks for the replies, battery looks easy. ....
The OEM battery does not have a carry strap, most replacement batteries do.
This comes into play when you try to put the battery cover back on.
You have to decide:
Remove the strap for a good fit
or
Leave the strap on for a 'not-so-good' fit.
I opted for the bad fit/leave strap, because I ain't getting any younger.
