Radio Noise install help
Old Dec 7, 2008 | 12:08 PM
Suzie68's Avatar
Need a little help guys,
I installed a P.I.E. adapter to use my satellite radio with the factory Aux button. Now I have a whine/whistle noise coming through the speakers. It is even there when the Sat radio is turned off. I have tried grounding the PIE moduale with no luck. Need some advise here.
Jon
Old Dec 7, 2008 | 04:22 PM
SSCULLY's Avatar
I would suspect the power source you selected is the cause of it, but there are a few posted problem with some that returned then and they were fine after the replacement.
Take a search here for PIE static as the terms for a few posts on the topic.
