p401 and cruise control
Old Oct 21, 2008 | 03:16 PM
jeffallred's Avatar
This might be a dumb question to some, but if I am getting a p401 could it eventually cause the cruise control to stop working?
I also just got the cruise control recall done about 2 months ago and my cruise went out about a month after that. I've had the code for a few months before that. I'm just wondering if it has to do with the recall done or the code or something completely different.
Thanks for your replies!
Old Oct 21, 2008 | 07:20 PM
SSCULLY's Avatar
The cruise going out could be a blown fuse in the new harness.
to test the cruise control :
There is a self test in the cruise control system.
With the key off depress and hold the cruise control off button while turning the ignition to the run position,don't start the truck, the cruise light will flash once to let you know it is in self test.
Five additional flashes indicate a bad cruise control servo
Release the cruise off switch and within 5 seconds depress the other switches in sequence:
1. on
2. resume
3. coast
4. set/ accel
The speed control light will flash as each switch is depressed.
If the last one does not flash it may then flash a code
After this the cruise will move the throttle to test the actuator and the cable.
Make sure the throttle returns to idle and turn the key off.
The P0401 DTC, do a search on it, there are 350 threads with P0401. The 4.6 is known for clogged EGR ports. Good thread on the topic ( still do the search )
https://www.f150online.com/forums/en...ode-po401.html
Old Oct 22, 2008 | 09:12 AM
jeffallred's Avatar
Thanks! Yeah I've done the search for the 401 code. I was just wondering if it could have anything to do with the cruise control issue. I will try the test when I get home.
Old Oct 22, 2008 | 09:25 AM
jeffallred's Avatar
One more thing. When I try to turn it on, I press the on button and then the set button and the cruise control light will flash on and then immediately back off.
Old Oct 29, 2008 | 10:31 PM
BorderFord4X4's Avatar
I tried this on mine and the light didn't even come on, any ideas? 2004 F-150 supercrew 4x4.
Old Feb 18, 2009 | 12:26 PM
jeffallred's Avatar
Well I haven't tried the self test yet, but I finally called the dealer to schedule an appointment and they said there is no way it could be the new harness and they were going to charge $77.50 just to check it out. Are they just bs-ing me or could it be the recall harness?
Old Feb 18, 2009 | 01:31 PM
SSCULLY's Avatar
Just had 2 other threads, where the dealer the member used, claimed the recalled harness had caused a problem.
I guess it depends if you have a 1st gen or 2nd gen recall harness
Old Feb 18, 2009 | 02:01 PM
jeffallred's Avatar
They want $77.50 just to check it and probably not tell me if it was the harness since they said there is no way it could be.
Old Feb 18, 2009 | 03:00 PM
SSCULLY's Avatar
Run the self test, and see what happens.
The 2nd gen harness has an ATM fuse in the side of it, that if there is a condition ( like leaking ) that causes a short to ground, this will blow. You can check with a meter from the end of the connector, to the far side of the fuse ( little metal pins in the back of it ).
Old Feb 19, 2009 | 08:46 AM
jeffallred's Avatar
I finally ran the self-test last night and it blinked after every button and when I hit set/accel, it flashed 3 times. What does that mean?
Old Feb 19, 2009 | 09:25 AM
jeffallred's Avatar
3 flashes - deactivator switch is open or circuit defective.
Okay I found what 3 flashes mean, but what does this mean?
Old Feb 19, 2009 | 11:30 AM
jeffallred's Avatar
So what do I need to do?
Old Feb 19, 2009 | 03:18 PM
jeffallred's Avatar
switch or harness or both or just a fuse in the harness?
Old Feb 20, 2009 | 11:04 AM
SSCULLY's Avatar
Sorry, yesterday was busy as all get out, just got back to this today.
The test for to find out what needs to be replaced, requires 1 more step.
Measure the voltage between the speed control servo C122 pin 9, circuit 307 (BK/YE), harness side and the speed control servo C122 pin 10, circuit 57 (BK), harness side.
If the voltage greater than 10 v, then install a new speed control servo.
If the voltage is less then 10 v( i.e. 0 v ) :
Measure the voltage between the deactivator switch C1025, circuit 10 (LG/RD), harness side and ground, for voltage greater than 10 V.
If no, there is a problem with the circuit ( which could be the ATM fuse in the harness ).
If yes:
Measure the resistance between the speed control servo C122 pin 9, circuit 307 (BK/YE), harness side and the deactivator switch C1025, circuit 307 (BK/YE), harness side for resistance less than 5 ohms.
If the resistance is less than 5 ohms, a new deactivator switch is needed.
If the resistance is greater than 5 ohms, there is a problem with the circuit ( again could be the ATM fuse in the recall harness).
