Turn Signal Fuse Blowing:help:
If you have an aftermarket, or factory for that matter. Trailer harness unplug it/take it out and recheck. I see this all the time at work!!! people who install scotch locks, dont soldier, and don't use heat shrink should be castrated!
If it still blows check your bulbs. An element could have broken and fallen onto the second element. Beyond that....multi-function switch, pinched wire, or bad bulb socket.
more info, and thanks for your replies
the fuse that is blowing is in the box under steering column near driver door, and the position is 13. The top fuse inthe center column.
the first time the fuse blew, a couple of months ago, I changed it out and the problem went away. about a week ago it blew again and now blow as soon as a insert a new fuse except for this morning when i got a box of fuses i plugged one in and the signal worked for about 10 seconds before blowing again.
