Whats wrong with my windows???
Old Oct 7, 2008 | 08:09 AM
LARABOY's Avatar
Exclamation Whats wrong with my windows???
ok can some one help me out?!
my driver side window had been accting up i have to push the button a few times before it moves and some times it just doesnt move at all. and now the person on the passenger sidecan put thier window up cause the button doesnt work.
HAS ANY BONE HAD THIS PROBLEM???
Old Oct 7, 2008 | 08:29 AM
SSCULLY's Avatar
I had the problem with the driver's side on my 2006, it was the switch. Guess I had gotten rain in it. Replaced it, no more problem.
This is for a SuperCrew, which was 38.00:
Old Oct 8, 2008 | 12:36 PM
LARABOY's Avatar
so then the problem is the swithces and wut about the passenger side same thing??
Old Oct 8, 2008 | 01:14 PM
scott1981's Avatar
Same I have an 06 and recently had to replace both of mine. I took them apart to determine the problem and it appears to be a bent contact that seems to have been caused by pressing on the buttons too hard.
The swap is a piece of cake. Take a wide flat head screw driver and gently pry up the cover the switches are mounted on.
It will pop up then just unplug the switch block and install a new one. Took me all of 5 minutes and now everything works perfectly
Old Oct 8, 2008 | 01:18 PM
scott1981's Avatar
Oh and funny thing, the drivers side contains all 4 switches and is cheaper than the passenger that is only 1 switch
Old Oct 9, 2008 | 08:41 AM
SSCULLY's Avatar
The power for all the switches runs through the driver's side master switch, then on to the other switches. If the driver's switch does not work any more, al the windows don't work.
Considering you are having problems with the driver's side first, I would start with that switch alone, and see if it is the problem with the pass side window switch, which it could be that switch is also bad.
Old Oct 9, 2008 | 01:12 PM
LARABOY's Avatar
yea the other windows are fine the passenger cant put up thier window and the driver side sticks some times
