Starting Issue...need some help
Old Sep 30, 2008 | 02:35 PM
wtdavault's Avatar
Thanks in advance for any help. I will try to be as thorough as possible..
When I open the door to the truck the PCM relay under the dash starts to click on/off (interior lights do the same)..the lights on the dash come on as normal..when I turn the key over the starter relay on the firewall clicks loudly and the starter will not engage. The battery is only 3 months old and I have replaced the starter relay and the PCM relay both this morning with no success. I have a hard time believing the starter would make the PCM relay behave like it is, but I have no clue what to try next. There have been no symptoms of any problems before now. Any suggestions??
Old Sep 30, 2008 | 03:00 PM
jward's Avatar
Have you tried to jump start it? If you do, and it starts, I'd pull the battery and have a parts place run a check on it.
Begin with the easy stuff first. Go from there.
Old Sep 30, 2008 | 03:54 PM
02SC4x4's Avatar
x2!
