'02 Ford F-150 - Brakelights & turn signals out?
Old 08-08-2008, 12:49 AM
jkvega's Avatar
Would this be a fuse, and can someone tell me which number fuse it would be? I have a Atm-20 fuse I just bought here, but can't find owner's manual. I'm needing to know where it goes, and if that one will even work for that matter. Someone else with an '03 said 13, but tried it, and fuse is too small to fit.
Old 08-09-2008, 09:55 AM
roc4950's Avatar
On my '97 the brake/ turn signals are on fuse number one and shows it to be a 15 amp fuse. My fuses are the mini fuses. Don't know if this helps.
Old 08-09-2008, 10:21 AM
FX41's Avatar
For the 02s, brake lights and turn signal, are fuse number 13, 20a. Now that is also assuming that the position of the fuses is standard for all 02s and doesn't change with models, ie, Screws, Scabs, Rcabs. HDs, KRs and the such becuase I don't know what your trim package or body style is. The amp you have that dosn't fit, is it because it is too large are becasue it is too small, they make 20a fuses in the mini too.
hope this helps!
Quick Reply: '02 Ford F-150 - Brakelights & turn signals out?
