Driver side heated seat
Old Aug 7, 2008 | 11:50 PM
4x4King's Avatar
Well my driver side heated seat isnt working. i tried changeing the heater module from the passanger side to the driver side and the driver side still doesnt work (the passanger side does). what do you guys think is wrong?
At first i thought it was the heating element but, dont you think it might be more likely that a fuse or wire has gone bad?
Old Aug 8, 2008 | 12:13 AM
Rockpick's Avatar
Moderator &
I ask this of some of the older members (anyone, of course, should pitch in though)
Didn't another member have trouble with their heated seats on a the original body style KR? I know this sounds familiar for some reason.
Old Aug 8, 2008 | 12:24 AM
4x4King's Avatar
yea i thought i read somthing about it before but i cant find the link
Edit:
Ok i f ound the link i saw before but it only talks about the heating module. Im pretty sure its electrical or the heating element.
Old Aug 8, 2008 | 12:33 AM
Rockpick's Avatar
Moderator &
Yeah... I did a couple of quick searches as well... I couldn't put my finger on it either.
I may be off my rocker - trust me, I've been accused of that way more than once - but, I really think there was some talk about it...
Obviously, you've checked the fuses and stuff like that, right?
Old Aug 8, 2008 | 12:38 AM
4x4King's Avatar
not yet because i thought i read that there where 3 fuses to check but im not sure what ones they are. If its wiring how can i be 100 percent sure thats what it is. Whats more likely to go the heating element or wires and fuses.
Old Aug 8, 2008 | 12:52 AM
Rockpick's Avatar
Moderator &
Fuses... check the fuses.
Those are the low-hanging fruit. Definitely the easiest place to check.
Your manual will detail which fuses run the heated seat system.
Once you check that and rule that out, then go to wiring and such... maybe even the switch.
(#25,000)
Old Aug 8, 2008 | 12:59 AM
4x4King's Avatar
Switch meaning the button to turn the heater seat on?
i dont think its that because there is a orange led light on the button that shows up. (I dont know if the light has anything to do with the button going bad.)
Old Aug 8, 2008 | 01:34 AM
FX41's Avatar
If the light is coming on then I think the switch is completing the circuit, which would tell me that the swith itself is working.?.?
Old Aug 8, 2008 | 02:31 AM
4x4King's Avatar
yea i thought the switch was working cause the led light was on but, the seat never gets heated.
Old Aug 8, 2008 | 07:57 AM
Rockpick's Avatar
Moderator &
Yeah. That's the one. Because the light is lighting up, I think it's likely that you're getting power on the circuit... which, to me, means that it may be another gremlin - like you previously mentioned.
Old Aug 8, 2008 | 02:09 PM
4x4King's Avatar
Ill Check the fuses anyway if it not that then i hope its a wire lose.
Old Aug 8, 2008 | 02:25 PM
Rockpick's Avatar
Moderator &
King -- I'm going to copy this up to electrical. It may be such that someone up there can help a bit more (I can't find the heated seat thread here in KR to save my life). There will a redirect link from this forum directly into the Electrical forum to help in getting back to it.
Hey SSCULLY, friend ole' pal! Can you help my friend 4x4King with this? You know me and electrical...lol! Thanks, man!
Old Aug 8, 2008 | 03:15 PM
4x4King's Avatar
i check the heated seat fuse it looks fine and as far as i could tell there where not any loose wires. Can the heating elemant really go bad?
Old Aug 9, 2008 | 01:15 PM
4x4King's Avatar
Has anybody installed heated seats before, if so how hard is it? I was thinking about replacing mine i found this for $67.00 plus shipping $8.00.
Peak 11" x 11" Dual Pad Universal Carbon Fiber Seat Heater Kit
From the website http://www.heatmyseats.com/
Old Aug 9, 2008 | 09:07 PM
Rockpick's Avatar
Moderator &
*bump*
