Ford 500 Interior lights wen trunk is open ?!?!?
what year ?
There should be a "dimmer" switch or *** you can turn. It will dim the dash lights. If you dim them all the way, then make the *** "click" into position, it will turn off the interior lights and cargo light.
find the switch that tells the car when the trunk is open and tape it so it thinks its off or cut the wire
by the way what are you putting in your trunk that you dont want to draw attention to yourself????
