7-pin trailer connection
Old Jun 4, 2008 | 10:35 AM
rjmax's Avatar
I have a 2006 F150 with the standard 4-pin trailer plug on the rear. I would like to swap it out for the 7-pin using the OEM harness. Can anyone please tell me exactly what I need to do this? I need to have trailer brakes and also a battery charge circuit for the trailer. Is it true the trailer brake wire is already installed and just needs to be hooked up?
Old Jun 4, 2008 | 03:49 PM
SSCULLY's Avatar
You should only need to change the wiring from the connector by the spare tire, and install the relay and fuses for this.
Take a look at the sticky at the top of the towing and hauling forum, few members did the same thing you are trying to do already ( mind the part numbers, there are 99-03 and 04+ part numbers and diagrams in this thread )
https://www.f150online.com/forums/sh...d.php?t=184757
Old Jun 5, 2008 | 08:31 AM
rjmax's Avatar
So, is the brake connector that is up under the dash by your right knee on all trucks? Mine is a '06 F150 without the tow package.
Old Jun 5, 2008 | 09:28 AM
SSCULLY's Avatar
That one sounds like the ABS diagnostic connector ( left knee by brake pedal release / hood release area ? )
Look for another one, that is by the right knee, 6 pins ( 2 rows of 3 ), by the ODB-II connector.
This is from the trailer tow install that comes with the tow kit.
Drop me an email via my profile, and I can send you the trailer tow install directions scanned into a PDF.
Note the MY of your truck in the email, so I don't grab the wrong one.
Lord knows, I'll get the email, and in haste forget to look back here for your MY in your profile and send the wrong series ( 99-03 version or 04+ version ).
Old Jun 5, 2008 | 10:25 AM
rjmax's Avatar
SCULLY, I sent you an email.
Now, if I put the 7-pin factory harness in at the rear will it already have connected the trailer charge line and will I just have to install the relay(s) and fuses??? OR, will I also have to find that wire at the rear of my truck?
