Dash thermometer issue
Old May 17, 2008 | 07:47 PM
BuckshotMN's Avatar
I have a 2004 F-150 Lariet and started having trouble with my in-dash therometer. It wildly fluctuates to as high as 30 degrees over the ambient air temperature. I am not sure if it is the truck software or the sensor. Any ideas? Does anyone know where the sensor is located? Anyone ever replaced one?
Old May 17, 2008 | 07:50 PM
BigMan's Avatar
I think the sensor is in the front behind the grill
Old May 17, 2008 | 09:13 PM
warrantyvoider's Avatar
yep, when you open the hood, there is a support that is right in front of the radiator. on there should be the temp sensor and it has a wire running to it (i believe the wire runs into from the top but its the only thing on the support). just disconnect and replace.
Old May 31, 2008 | 12:55 AM
justplyn's Avatar
On a similar note... My light went out on the dash so I can see the temp, how do you replace that?
Old Aug 17, 2008 | 01:04 PM
mcmsys's Avatar
Mine reads 12* lower than it should (it reads 70* when it is 82* outside). Is there an adjustment somewhere?
Old Sep 3, 2008 | 04:07 PM
G W McLintock's Avatar
I have the same problem with an inaccurate temp reading (off by 20+ degrees). Is it a sensor problem or an adjustment? Or should I do like I did with my VCR and just put black tape over the display?
Old Oct 10, 2008 | 06:58 AM
mickdigler's Avatar
I've got the same problem, it reads 50 degree's warmer than it actually is. Anyone know the part number for an 04?
Thanks!
Old Nov 11, 2008 | 08:06 PM
chiz33's Avatar
I have a problem too! Mine reads 50 degrees celcius all the time which is like 122 degrees Fahrenheit. Definitely not that hot up here in Canada! Should I replace the sensor? I like to know when it is below freezing outside.
Old Nov 19, 2008 | 08:00 AM
njtek's Avatar
Anyone get the part number for this yet?
Thanks!
Old Nov 19, 2008 | 06:18 PM
gtr986's Avatar
Hi Guys,
About 10deg low here. Looking to replace mine as well. Without having located the sensor on my '05 to see what it looks like, I *think* the part number is YH479. If anyone knows what it looks like, just google that part number and see if it looks like a match.
Thanks!
Old Nov 19, 2008 | 07:56 PM
gtr986's Avatar
Hello again,
Just popped my hood on my '05 and found the sensor. It's sitting here in front on me now. The part number I posted previous is NOT correct. I see this number stamped on the part.... F3VF-12A647-AA, though that turned up nada on an internet search. I was able to find what appears to be the same part under Standard Motor Products p/n TX45 and p/n TX12. I'll probably just run by the dealer and say 'give me one of these'. Should take all of 3 seconds to snap it back into place.
** edited to add....
The replacement part I received has the following part numbers on the box.... DY-1054 and 5W7Z-12A647-A. I have an accurate temperature reading again.
