Lights mounted. NEED POWER!
Old May 11, 2008 | 05:46 PM
Camarothatcould's Avatar
I mounted 12 running lights today. 4 on each running board, and 4 in front. I wanted to divide the lights in two, 6 on each side. I wanted to wire the left side of the running lights in with the left turn signal so all of them blinked with the blinker on. Visa versa. I think its too much of a load, any suggestions? Or any other way of wiring them? I DO NOT want an after market switch to turn them on, I want them to be wired in with the stock parking lamp switch also. PLEASE HELP! Thank you
Old May 11, 2008 | 06:31 PM
NoLongerJeepin's Avatar
If you wired them up through a relay you should be ok.
Old May 11, 2008 | 06:53 PM
A relay on each side off of each corner light?
Old May 11, 2008 | 06:54 PM
Yeap, same concept as adding reverse lights that go on when the truck is put in reverse
Old May 11, 2008 | 07:03 PM
Realy is how I have my big spotlights wired up. Flip my brights switch and the spots come on along with brights
Old May 11, 2008 | 07:08 PM
Then thats going to be your best bet.
Old May 11, 2008 | 07:11 PM
So I take a wire off of the factory switch that gives power to turn on the corners, take that, splice it to 2, run one to a relay on each side, run a terminal to power, wire to the lights themselves, and ultimately a ground.
Old May 14, 2008 | 05:51 PM
LastSplash's Avatar
If you wire the lights to come on with your blinkers you may have to install a heavy duty blinker relay to prevent the blinker from flashing real fast.
Old May 14, 2008 | 06:54 PM
mark03screw's Avatar
nice corner lights! Whered you get them?
Old May 14, 2008 | 07:29 PM
Ebay. I still see them on there for like $10
Old May 23, 2008 | 11:37 AM
SVonhof's Avatar
Link? Ebay #?
