One Touch Window Down
Old May 7, 2008 | 08:45 AM
xpress4me2's Avatar
Talking One Touch Window Down
200 f150, one touch driver side window will not go down. Clicking when button is pressed. Changed # 4 relay still will not go down, clicking sound still there. Any ideas would be appreciated.
Old May 7, 2008 | 09:05 AM
05_sprcrw's Avatar
It may be a faulty switch. I have had to replace the switch before on another vehicle to get it to work properly.
Old May 7, 2008 | 09:33 AM
crash_lucky13's Avatar
take the cover off the door and TAP on the window motor regulator thingy... then try it... sounds to me like the motor is ~dead~
Old May 7, 2008 | 10:46 AM
SSCULLY's Avatar
If the window works normally ( press and hold, moves down ), I woudl agree with 05_sprcrw, the OTD part of the switch took a powder.
The switch in my old 2001 is still working fine, but I had to replace the switch in my 2006 already ( down contacts ).
You can test this by removing the switch and jumpering ( momentarily ) the light blue w/ black stripe wire to the gray wire. The light blue w/ black stripe is the power to the switch, and the gray wire is the OTD trigger to the GEM.
Old May 7, 2008 | 11:01 AM
xpress4me2's Avatar
One touch window down
The switch does not work at all, it is stuck in the up position. I removed relay # 4 and hit the down switch, clicking stopped so I got the right relay. Passenger side works fine. Does anyone have instructions on how to remove door panel.
Old May 7, 2008 | 01:09 PM
SSCULLY's Avatar
Sorry, you mentioned the OTD relay, so I thought it was only that part of the switch, my mistake.
You can download the the directions from Muth on installing the mirrors for the truck.
http://www.muthco.com/
Here is a thread on how to get the motor out of the door :
https://www.f150online.com/forums/sh...ghlight=window
Good luck.
-sms
Old May 7, 2008 | 01:42 PM
xpress4me2's Avatar
Smile One touch window down
Appreciate everyones suggestions. Went out for lunch and decided to remove the switch and replace it, since the relay was not the problem. Thought I would disconnect it and reconnect and give it a try, lo and behold it worked. I'm guessing a contact must have been jarred loose. I work with IBM computers (mainframes), sometimes the CE (customer engireers) do what they refer to as receding the cards, all this is involves is removing the card and blowing off any dust and re connecting to make suer it has a good contact.this has fixed many problems throughout the years, that is what gave me the idea to recede the contacts, saved me some $$$ and time. Anyway thanks again.
Old May 7, 2008 | 02:13 PM
but but but
lol glad you fixed it...
still better hit it with a hammer a few times just to remind it who the boss is though
Old May 7, 2008 | 02:28 PM
SSCULLY's Avatar
Originally Posted by crash_lucky13
..<snip>...
Percussion Adjustment is what we call that in the Telecom industry.
I have a tenancy to start with yelling at it:
"WORK B*&#$ !! Work, or I'll through your @%% in the garbage ! "
That was a lame post for # 4010
BTW that is re-seating the card. The nice way of saying percussion adjustment
