Power lock motors...
Old Apr 29, 2008 | 04:11 PM
SlammaJamma's Avatar
I know it's a normal thing with Ford's to have your power locks go out after time. For anyone who has replaced them, where did you get the motors from? I've looked at a few sites online and have found nothing. Is it a dealer only item? Thanks in advance.
Old Apr 29, 2008 | 07:10 PM
cva-59's Avatar
Power door locks
They are called actuators. You can try varsityford.com. I looked they were about $44.00 each. Uou can also try Tasca Ford
Old Apr 29, 2008 | 10:53 PM
Thank you sir
Old Apr 30, 2008 | 04:32 AM
DRJ's Avatar
DRJ
I haven't replaced factory actuators, but I have installed countless aftermarket actuators and they turn out great, you could just add your own if u cant get 'em but I doubt it
Old May 5, 2008 | 12:03 AM
edquipt's Avatar
Go to allelectronics.com... They've got actuators available for $5.50/ea. Ordered 2 of them just last night to replace mine and you can read reviews there of others that have used them for their Ford products.
Old May 10, 2008 | 12:11 AM
cakeeater2's Avatar
there is a forum on here that describes in detail how to fix it on the cheap. i did it back in oct. and they still work like they're brand new. i will see if i can find it again it will post a link to it.
Old May 10, 2008 | 12:52 AM
cakeeater2's Avatar
https://www.f150online.com/forums/sh...ght=thermister
here is that link to the step by step. the way i see it is you was plannin on replacing the actuators anyway so why not try this first? like i said i did it bout 7months ago and mine still pop ev time i hit the button either in the truck or on the key fob. only thing i did differently was i went ahead and short circuited the spot where the thermister goes because the only way you will burn up your motor is if you sit there holdin down the button constantly. so don't hold down the button and don't let your kids(if you have them) sit there and play with them and you will be fine. better than 45 bux a piece!!
Old May 10, 2008 | 12:55 AM
cakeeater2's Avatar
oh yeah i forgot it is the tenth post down it is titled Budget door lock actuator repair.
Old May 12, 2008 | 10:41 PM
ThomF150's Avatar
thanks....I have had Mine for a year and they wont lock with button or fob, only when put in gear. but they wont unlock at all with fob, switch or keyless entry pad. Ill try this next
