2 quick questions for efan install
Old Apr 12, 2008 | 08:10 PM
Jeff2005F150's Avatar
Hello
I have tired searching for this but can't find anything.
I was wanting to know what the positive wire color is on the ac pump? So I can wire some efans into it??
Also what is a good place to run a wire to if you need to have the power only when the key is in the on position?? besides the radio
Old Apr 12, 2008 | 08:28 PM
please use a relay if you are running off of the compressor clutch harness. usually its darker is ground and lighter is positive, not sure what wire colors you have.
you can always tap into the ingition wire, but again be sure to use a relay so you dont jack with your trucks wiring
Old Apr 12, 2008 | 09:49 PM
Cool thanks. I should of added I am using an adjustable thermostat that has a relay included it has a wire for the AC included. Would I still have to use an additionl relay for the AC condenssor?
Do you know what the color of the igintion wire is of the top of your head??
Old Apr 13, 2008 | 01:25 AM
nope but your security module should have all of the wires listed on it, i can look it up later for you. email me
