where can I find code for keyless pad entry
Old Feb 19, 2008 | 10:24 PM
casinada's Avatar
First of all, thanks ahead of time. I recently purchase a used 2004 f150 and it has the keyless pad entry. My questions is, can someone tell me where to find the keyless pad code for my f150? My truck is the regular cab not the crew cab or the super cab. thanks again.
Old Feb 20, 2008 | 01:41 PM
SSCULLY's Avatar
If you are talking about the new body style 2004 ( not the Heritage version std cab ) it is on the back wall, below the rear driver's side speaker on the C-pillar.
You would need to remove the c-pillar cover, and read the factory code on it.
If you are talking about the 2004 Heritage ( old body style like the 2004 L ) that is under the dash :
https://www.f150online.com/forums/sh...d.php?t=319924
Old Feb 20, 2008 | 02:55 PM
Brodie_J's Avatar
If it came with the manual, there should be a little card in there with the code on it.
Old Feb 20, 2008 | 06:34 PM
casinada's Avatar
Thanks Brodie J but my truck did not have the card when i purchased it.
I found the code, however, it was exactly where SScully said it would be. Thanks SScully for saving me a few bucks.
Old Feb 22, 2008 | 02:15 PM
screaminyellow's Avatar
You mean you cannot change the factory code? Or, you need the factory code to change it?
Old Feb 23, 2008 | 12:45 PM
quick350's Avatar
same question
i have 05 scab fx4. is it in same place? thanks
Old Feb 24, 2008 | 01:46 PM
SSCULLY's Avatar
SCab & SCrew are in the center of the rear wall, behind the seat back.
Here is a quick write up I did on the removal, using Member input.
Right click save as :
http://my.voyager.net/~sscully/04and...eatremoval.doc
Any additional is more then welcome
Good Luck
