Thermometer and compass have stopped working
Old Oct 20, 2014 | 04:02 PM
norman0954's Avatar
circuit board
Originally Posted by kburchak
mine did same remove from truck and inspect circuit board i found component had cracked off board soldered back on compass and temp work again 10 min fox
I found the resistor marked 510 touched them with some solder and it fixed my problem less than 30 minute fix
Old Oct 28, 2014 | 10:56 AM
TX Ranger's Avatar
I think it's worth mentioning, that even if the resistor doesn't look like it needs solder; i.e. looks perfectly ok, give it a whirl anyway. my looked perfect, and a dab of solder worked as well.
Old Apr 3, 2016 | 08:23 PM
chavezolivasfam's Avatar
Thermometer and compass not working
Found this forum and followed instructions and everything worked as demonstrated. Thanks very easy.
Old Apr 3, 2016 | 09:15 PM
Glad it worked for you. Stick around and join in some of the discussions.
Old Jun 19, 2017 | 12:37 PM
Mooner's Avatar
Originally Posted by jmaddox2008
i have a02 F150
My Compas/Temp goes blank too.
but it comes back on after a while.
Like it has a mind of its own.
That verifies you have a female truck.
Old Jun 28, 2024 | 06:57 PM
JRHendricks's Avatar
I had a similar issue, compass and thermometer just stopped working. Pulled it apart, and saw one of the 501 surface mounts was loose. I soldered it back into place, and it works again.
