Aftermarket reverse lights or light bar
Old Jan 30, 2008 | 04:24 PM
crumbrian's Avatar
I would like to add some additional lighting to my reverse for backing up due to the tinted windows making it hard to see. I have seen 3 options and would like to know your thoughts and experiences...
There is a reverse light that goes on the hitch and has to lights. It plugs into the 7pin towing harness/adapter. And also has a switch on it to turn on manually.
Second, there is the Fire/Ice Lights that goes below the tailgate and acts as a 3rd brake light, blinker and reverse. How bright are the reverses on this?
And last, buying some small piaa or hella driving lights and wiring them into the reverse wire to turn on. I could mount these under the hitch somewhere.
Thanks for the input!
Old Jan 30, 2008 | 06:58 PM
SSCULLY's Avatar
Originally Posted by crumbrian
...<snip>...
There is a reverse light that goes on the hitch and has to lights. It plugs into the 7pin towing harness/adapter. And also has a switch on it to turn on manually....<snip>...
Is this the White Knight kit ? I tried one of these, and if you tow, plan on removing it, else you need a really long hitch adapter, to reach back into the factory hitch. I tried one for about 35 min, packaged it back up and sent it back.
...<snip>...And last, buying some small piaa or hella driving lights and wiring them into the reverse wire to turn on. I could mount these under the hitch somewhere.....<snip>...
This is what I did with the Truck Lite backup LED light heads. I used the reversing circuit on the truck to power them in reverse mode. They draw 1 A each light head, vs. 4.58 A each light head for 55W driving lamps.
If you plan on placing the manual reverse lights on switch in the cab of the truck, no big deal to use normal driving lamps, as you are going to be running wire front to rear on the truck already ( access to battery for fog / drivng lamp circuit ).
Here is a picture of the truck-lite reverse lamps on my 2001 SCrew at night ( same ones I now have on my 2006 )
Sample diagram for adding 55 W fog lamps to the rear of your truck, with the manual turn on switch in the cab of the truck :
Old Jan 30, 2008 | 07:05 PM
j2h1's Avatar
Thats a sweet idea SSCULLY. I love 'em!
Old Jan 30, 2008 | 07:37 PM
Larry227's Avatar
I have the White Knight and it works fine for me and is very bright. I bought the model that clamps on and can stay in place with a hitch. No problem getting a hitch in or out. You have to hook it to a power source and reverse light wire, both of which are on the 7-way trailer plug.
You can see how it looks on mine in my gallery. Some receivers let it sit farther back under the bumper so it's flush. That might make getting a pin in and out difficult though. I'll have to ask a guy at work that has his flush with the bumper.
