Horn And Cruise Control
The one I saw it was an ATM fuse under the harness tape. That was a recall harness revision 1. I think there were 3 revisions total.
it was made to be non serviceable.
Unplug the recall harness, and jumper the end of the factory harness and rerun the CC self test.
Cruise control
VIN: I can send you in email
Expedition cruise
I have a 1998 Expedition. My cruise will not work. It worked this morning but this afternoon it did not. The switch on the master cylinder has fluid inside it but I get a reading on a volt meter when I touch the terminals. It is the recall jumper harness, so it's been replaced. I also get a reading on the volt meter when I touch the contacts inside the harness. All my fuses under the dash are good and my horn works just fine.
What would be the cause for this "all of the sudden" break of the cruise?
