Battery Problems
Old Jan 14, 2008 | 12:22 AM
hillbilly4u's Avatar
Battery Problems
Are the OEM batteries junk? My truck only has bout 3000 miles on her and I'm havin to boost it off in the mornings. Will do fine for 4 or 5 days then bam its dead.
Old Jan 14, 2008 | 01:29 AM
roushstage2's Avatar
Are you sure it's not the alternator? My Ford battery is still going strong after 6 years in my car. IMO, the Ford OEM batteries are really good.
I'd take it in and have it checked.
Old Jan 14, 2008 | 03:19 AM
Old Dogg™'s Avatar
Mine was junk...started having to jump my truck after 1 month. Dealer said it was in specs for months.
There is another post on the same topic;
Look at 06 F150 OEM Battery...
seems they put junk in many trucks.
Old Jan 28, 2008 | 05:51 PM
Supercrew333's Avatar
Just took my 07 Screw 4x4 5.4 fx4 in with battery problems. Last week on two mornings 9 deg. and 11 deg the truck would turn over 5 or 6 times and dead battery. I had to jump it. Took to dealer today and they ran test on battery and put in a new one. My last F150 a 98 has the original battery, I had the truck 9 years and when I traded it in August of 07 it had the original battery going strong.
Old Jan 28, 2008 | 06:39 PM
STXDriver's Avatar
I also want to know what's going on and why something went bad but if your truck is still under warranty, let the dealer figure out what's wrong.
My new '06 Honda Gold Wing was less than 6 months old when the battery had to be replaced.
What prevents everything from being perfectly made or assembled without flaws is that most all manufacturers can't afford to do 100% inspections to catch defective parts.
Thank goodness for factory warranties.
Old Jan 28, 2008 | 07:18 PM
JackandJanet's Avatar
Looking at your mods, you might have something that is "constantly" on (like the radio or the GPS) and that is what is draining your battery when the truck sits.
I was going to try to explain what I went through to check for this problem on my truck using an ammeter, but it's way too complicated. They should be able to do this at the dealership. -or- you could pull the fuses or unplug the radio and GPS and see if you still have a battery that dies on you. If not, one of these mods is sucking on the battery while you're asleep.
Good luck - the electrical system in these new vehicles is NOT an easy thing to troubleshoot. BTW, there's always a "small" drain on the battery to maintain the computer's memory, the clock, anti-theft alarm and any radio station presets.
- Jack
