Fuel pump questions?????????
Old Dec 29, 2007 | 10:55 AM
El Boricua's Avatar
My 1999 F-150 Extended Cab is blowing the F18 fuse from time to time. I did spray some engine degreaser and some water in the engine bay to do some cleaning in the morning and I started the engine for about 20 mins. right after the cleaning with no problems.
Then went for a ride and problems started. The engine start and run but sometimes blow the F18 fuse and quit. After this the engine crank, but won't start. I already know from a previous fault about a year ago that this fuse power that PATS module and I think it have something to do with the fuel pump relay. I checked harness for short circuit with no luck. When I replace the fuse it blow it right away. Then I wait let say 15 mins. change the fuse and I'm able to start the engine again. I checked fuel presssure and I have about 30 PSI witch I already know is getting low. I think the fuel pump is going south and the current is getting higher little by little until the fuse is blown. I also notice that with the engine running If I disconnect vacuum at the regulator the fuel pressure raise to 40 PSI.
Does this make sense?????
Other questions, How I could tell if the problem is indeed the pump or maybe the pressure regulator???? Can someone tell how much current the pump should take??? I'll try to change both of them anyways. This truck got 130K miles on it and I think it deserve it. Any advice on changing the regulator????? Just want to know in case I run into a similar problems in the future.
Thank you in advance for any help and Happy Holidays
