Quick Starter install question...
Old Dec 28, 2007 | 03:03 PM
pump9's Avatar
Quick starter question for a 98', 4.2
so after over 280K kms.... i finally had to replace the starter... but in the process i forget which cable is which.... i know its a stupid question but i thank you in advance.
im pretty sure the one off the battery goes to the solenoid and the black one to the starter mount (gnd) but id really like to verify before i melt it
Also in the process of getting the old one off i broke the wires off the ... O2 sensor just forward of it, right at the connection.... at least i think its the o2 sensor..... its mounted directly into the block, couple thin wires into a green connector... all shrouded by a 1/2 circle shield (obviously not big enough)
THANKS
Old Dec 28, 2007 | 07:05 PM
pump9's Avatar
anybody????
thanks!
Old Dec 28, 2007 | 08:26 PM
dirtmerchant42's Avatar
if no1 with advice chimes in check out v6f150.com and see what they have to say
Old Dec 29, 2007 | 12:47 PM
pump9's Avatar
thanks... i will go there... i got the starter in and up.... any ideas on the sensor ahead of the starter????
