2003 dome light
Old Dec 28, 2007 | 11:47 PM
jryans's Avatar
2003 dome light
I have a 2003 F-150 supercrew my interior lights will not come on when i open the doors or with the dimmer switch on the dash. The bulbs all look good and the map lights work when i turn them on. Was wondering if the relay in the fuse box may be bad. When i pulled it out the map lights went out. Just wanting some derection so i dont order a part that wont help me
Old Dec 29, 2007 | 08:18 AM
torkum's Avatar
Here are the possibilies:
The courtesy lamps do not turn on with one door open -
1.GEM.
2.Door open warning lamp switch.
3.Circuit(s).
4.Interior lamp relay.
5.Battery saver relay
Old Dec 29, 2007 | 09:56 AM
SSCULLY's Avatar
Are both the front & rear courtesy lamps out ?
The lamps that are controlled by the battery saver relay ( triggered by the GEM )
1. glove box
2. Map lights
3. Interior lamp relay
3.1. Cargo lamps
4. Interior lamps
The cargo lamps, and the door entry lamps ( think these were removed by 2003 ) are the only lamps without a separate connection to the battery saver relay.
The glove box, vanity mirror and engine compartment lamps are the only lamps without a connection to the interior lamp relay.
Check the list, if the cargo lamps work with the door or dimmer switch, I would say replace your bulbs in the truck.
Both the battery saver relay and the interior lamp relay obtain power from the same hot at all times fuse #14. Running board lamps have a separate fuse if they are installed.
Old Feb 9, 2008 | 06:26 PM
FENIXX3435's Avatar
I'm having the same trouble with my 02 F-150. Just wondering how and if you got it working? Thanks for any help.
Old Feb 9, 2008 | 08:35 PM
torkum's Avatar
Did you check fuse #14?
