Need help wiring in power windows to ignition!
Old Dec 20, 2007 | 05:51 PM
05'ThumpinSTX's Avatar
I'm almost done with my power window/lock install but I wanted to make sure that I wire the windows into the ignition correctly. Do I connect the (red) power wire to the Blue/green wire? And is the Blue/green wire a rather large blue wire with a green stripe? Also which wire on my headlight switch do I connect the switch Illumination wire to?
Old Dec 21, 2007 | 11:12 AM
Meatwagon's Avatar
www.bulldogsecurity.com =
Old Dec 22, 2007 | 05:23 AM
DRJ's Avatar
DRJ
04+ wiring
brown = prklts + behind the light switch.. take the panel that is on the side of the dash off to access it better
