Floor heat Problem
Old Dec 12, 2007 | 02:47 PM
ozzie615's Avatar
Floor heat Problem
I have a 2001 F150 with a heating problem when I put the heating control to floor it blow's very little on floor and 80% to the defrost, this also happens with the panel/floor heating position. I did some basic checkes and not sure where else to go, any help would be appriciated.
Old Dec 12, 2007 | 05:41 PM
wde3477's Avatar
Sounds like either a diverter is hung up or binding, or the actuator is not working. It helps to have a shop manual to show the layout and the various actuators - rather difficult to describe in words.
Old Dec 12, 2007 | 09:27 PM
No-Tyme's Avatar
Do they still use the vacumn lines for this as they use to???
Old Dec 12, 2007 | 10:41 PM
KDracing's Avatar
on my 2000 i still have vac lines for the zone control.
Old Dec 13, 2007 | 07:18 AM
No-Tyme's Avatar
I had that problem on my last Chevy truck... A rubber line came loose and I had no control of heat distribution, as it came out of most everywhere... My 68 Buick was corroded up and once I took it apart and cleaned and lubricated it has worked fine. My work in progress…
It might be worth crawling under there and giving it a good once over for a disconnected rubber line of a cracked one. Especially if you have been under there lately doing some work.
