01 with "Halo" light problems...
Old Dec 11, 2007 | 06:08 PM
taymax14's Avatar
I just bought a 01 F150 and it has upgraded front headlights. I think they are halos of something. when I have the regular lights turned on one of the round lights in each headlight is on. when I flip on the brights I have no lights. I also don't have the blue dash light indicating the brights are on. I checked all fuses and they are all good. anyone have any ideas besides just the wiring being done wrong? but what would explain not having the dash hi-beans indicater?
Old Dec 12, 2007 | 03:42 PM
taymax14's Avatar
update: so I went through the lights again today. and when I was playing in the fuse box the fuse for the hi beams is not blown put when you push on it or put a little pressure on it the highbeams go on then when you let off the fuse they turn off. so it doesn't have a very good connection. any ideas how to fix this? I tried other fuses to see if it would fix it but it didn't. right now I just have a piece of rubber inbetween the fuses holding it down so it works, but I would like to have a more perminant fix...
Old Dec 13, 2007 | 08:45 PM
phattbaztard03's Avatar
if you take out the fuse and bend the ends a little then that should help the connection out some. also do you know where i can find a wiring diagram of the fuse boxes????
