Urgent! Trying to locate speed sensor wire for 05 F150
Old Dec 4, 2007 | 10:16 PM
Truck gal's Avatar
Could anyone tell me the color of the speed sensor wire for an 05' F150, as well as it's location. My husband is trying to install a distance meter and cannot find the a gray and black wire that the manual is calling for.
Old Dec 5, 2007 | 07:32 AM
projectSHO89's Avatar
There isn't one, per se.
Vehicle speed data is taken from the ABS sub-system and is sent to the PCM via a network message. From there, it is distributed as needed as computer data.
It is likely possible that the OSS sensor on the tranny or the rear ABS sensor can provide the needed signal. You'll probably need to consult the device manufacturer's tech support for specific requirements for the device you purchased.
Steve
Old Dec 5, 2007 | 07:48 AM
DRJ's Avatar
DRJ
I heard sometime somewhere that the gray/blk wire for the VSS is on the radio plug...
Old Dec 5, 2007 | 10:51 AM
Good catch. I forgot about the speed sensitive audio control.
Yes, that is where the GRAY/BLACK wire runs to (also to the wipers on early 05 models) from the PCM.
Steve
Old Dec 5, 2007 | 01:27 PM
DRJ's Avatar
DRJ
Steve
Really? wipers... that's another one to add to the useless knowledge bank in the ol' noggin! is there anything you could do with that wire, such as hook it up to an alarm to activate your wipers?
Old Dec 5, 2007 | 08:56 PM
Apparently, speed sensitive wipers were available for a time.
Steve
Old Dec 6, 2007 | 03:01 PM
DRJ's Avatar
DRJ
Steve
Interesting..
+1 more for the bank
