Yes, I just returned from the UK. What this means is my 04 1F150 back up or reverse lights were dipped in yellow paint and became turn signals at the rear. My running lights at the front corners (yellow) are turn signals also. SO.... my brake lights still break red at rear, my normal high/low beams are fine. My additional rear red fog light (aftermarket, UK required) turns on with the front fog lights (no real problem). The small lights next to the front headlamps are clear (cant remeber if thats correct or if they were yellow, they dont signal if they use to) anyway they turn on, clear, same color as headlamps when that switch is initiated. Finally, at the rear again, the top red lamps (used o be turn signals and break lamps) are only used as brake lights and night running lights as I checked. My deep questions, since I cannot find any splices at the rear and I cannot identify where the reverse light comes into the junct box, where is my problem besides the obvious..that my scab is screwed! Anhow, if I had to guess, since my top rear red breaklights always broke properly b4 but were also blinkers(turn sigs) and now rear turn sigs are dipped yellow (below at clear portion of bezel, where the back up lights were) there are two wires reversed but Where? That is the question. Any takers? Or am I off to ford to spend money????
