Fog Lights?
Old Nov 16, 2007 | 10:56 PM
StickyF250's Avatar
Fog Lights?
I'm looking to add a new front bumper to my 06...
I want the bumper from the 04-05 with the square fog lights and tow hook holes.. Not the round fog lights...
If i get that bumper and buy the fog lights, do i need anything else, or is it just straight plug and play??
Anyone have the part numbers?
Any info would be greatly appreciated
Old Nov 17, 2007 | 12:37 AM
Tasca Ford Parts's Avatar
Former Sponsor
send me an email dstangelo@tasca.com and I will get you a list of part numbers on monday when I get back to the dealership
Old Nov 17, 2007 | 12:55 AM
StickyF250's Avatar
E-mail sent...
Still need to know if the 04'-05' bumper will fit on the 06 and do i need anything else besides the lights.... Not sure if that's something you can find out at the dealership..
Thank you
Old Nov 17, 2007 | 02:42 PM
andrewc_11890's Avatar
Hi, I don't want to hi jack this thread but a similar question, I have an 03 that doesnt have fog lights or tow hooks. Can i put on a new valence with fog lights and tow hook holes? Will the tow hook be able to still hook up to my truck even though there arent any on it now.
Old Nov 17, 2007 | 04:11 PM
Former Sponsor
The 06 bumper fits on the 04-05 so I don't see why you couldn't go the other way. As for the question on the 03 the tow hooks bolt into the frame and I am pretty sure when you look up a frame in the parts catalog it does not have tow hooks as an option. If you change the valance to a tow hook and fog light part you should be able to bolt the hooks in. You may have to change over a bracket that is there at the end of the frame rail. Drop me an email and I'll get you some part numbers.
Old Nov 17, 2007 | 04:28 PM
anaheim_drew's Avatar
Originally Posted by Domlogic
The 06 bumper fits on the 04-05 so I don't see why you couldn't go the other way. You may have to change over a bracket that is there at the end of the frame rail. Drop me an email and I'll get you some part numbers.
I have been asked by a few owners of the 06-07 how they can do the bumper swap because they like the 04-05 style fogs
Emailing you now.
Old Nov 17, 2007 | 04:41 PM
BMW5's Avatar
I tried to install an 05 bumper on my 06 F150 and it would not work. The mounting holes are different.
BMW5
Old Nov 17, 2007 | 09:13 PM
StickyF250's Avatar
Alright so you tried to install an 05' Front bumper on your 06' and it did not fit?
What was wrong with it?
Anyone else have any more information on this subject... I'm trying to order these parts before my leave is up and get the work done.. I ran to the local salvage yard today, now a salvage yard in CA is nothing like the one's back in MD... They did not have a single new body ford....
Also... With the fog lights, i understand the harness is there.. Do i need a new switch?
Old Nov 18, 2007 | 04:01 PM
BMW5's Avatar
The top portion of the bumper which connects to the frame is designed differently on the 04/05 model compared to the 06/07 model. Trust me, I tried to install the bumper with the square foglights on my 06 and it DID NOT fit. Don't waste your time or money as I did unless you plan on doing extensive modification to your truck and bumper to make it fit. It IS NOT an out of the box fit.
BMW5
Old Nov 18, 2007 | 04:10 PM
StickyF250's Avatar
Did you change any of the brackets out from the 06' to match the 04/05 bumper?
I've heard that if you take the brackets and the bumper it will work..
Now your saying it won't... So this sucks
Old Nov 18, 2007 | 04:20 PM
AlfredB18's Avatar
I did that with my 2003. Had the plain-jane valance and swapped to the one with fogs and tow hooks, but I don't have tow hooks yet. The holes are there in the frame rails, but it does look like a funky fit.
The only issue I had to work around was the deciding what hardware to use to bolt that lower valance lip on, since I didn't get anything with the package from Certifit...I think 10 3/8" x 1" bolts with corresponding lock washers and lock nuts hold it all together quite nicely considering the stealership told me the fastener clips (like those holding the upper valance) aren't stocked these days.
Old Nov 18, 2007 | 04:25 PM
Originally Posted by BMW5
The top portion of the bumper which connects to the frame is designed differently on the 04/05 model compared to the 06/07 model. Trust me, I tried to install the bumper with the square foglights on my 06 and it DID NOT fit. Don't waste your time or money as I did unless you plan on doing extensive modification to your truck and bumper to make it fit. It IS NOT an out of the box fit.BMW5
Maybe you did not have all of the parts and information you needed to complete the task
Old Nov 18, 2007 | 04:39 PM
StickyF250's Avatar
Ok so anyone with a 2006/2007 F150:
Have you swapped you bumper (complete) for a 2004/2005 bumper (complete) and got it to work?
Complete: meaning all brackets, hardware and parts needed
Old Nov 18, 2007 | 07:20 PM
BMW5's Avatar
Well, in that case; maybe it will work. I did not try to switch any brackets from the 04/05 to my truck. With all the modding it will take to mount the 04/05 bumper, you may decide it's just not worth the cost and time. Let us know how it works out for you.
BMW5
Old Nov 18, 2007 | 07:30 PM
StickyF250's Avatar
BMW5
So maybe if you use a complete 04/05 bumper it will just bolt right up to the frame. I can only image that the mount location for the bumper brackets did not change on the 05 frame o the 06 frame. So with the correct hardware and brackets, it should just "bolt" right up there...
What do you mean "with all the modding it will take"??
Does anyone know if an XLT is already pre-wired for fog lights, and where can i expect to find the connections if it is pre-wired.
