Horn!!!
Old Nov 12, 2007 | 09:35 AM
biglew347's Avatar
Horn!!!
Last night I was awaken at 1' o'clock to my horn blowing. I ran outside and just disconnected the battery. Has anyone had this happen and what caused it. I have an 2005 f250. Thanks, Lewis.
Old Nov 12, 2007 | 11:11 AM
projectSHO89's Avatar
Have you noticed any unusal air bag light indication?
Steve
Old Nov 12, 2007 | 01:50 PM
biglew347's Avatar
No Steve, I have not noticed anything out of the ordinary with the truck. Lewis.
Old Nov 14, 2007 | 01:45 AM
DRJ's Avatar
DRJ
next time it happens, insert your key in the doorlock and try unlocking it, if that don't work, try starting the truck, this will disarm ure factory alarm on ure truck
Old Nov 14, 2007 | 10:19 AM
biglew347's Avatar
I took the fuse out, but i'll put it back in and try that thanks, DRJ.
Old Nov 14, 2007 | 12:48 PM
mkosu04's Avatar
I think that is the Alarm Clock feature. It was an option for the latter part of the 04 model year and the early 05 models. Very handy if you have to get up early in the morning to drive to the job site.
Perhaps you accidentally turned the alarm clock on when you were changing the time last Sunday?
Old Nov 14, 2007 | 04:25 PM
biglew347's Avatar
I did not know that I'll check that right now. Thanks, Lewis.
Old Nov 14, 2007 | 04:37 PM
biglew347's Avatar
I checked in my maual and on the clock itself and did not find an alarm function.
Old Nov 15, 2007 | 01:02 PM
CRF250rider1000's Avatar
I am not sure that is really weird that it would just go off. It was just the horn and not the alarm correct?
Old Nov 15, 2007 | 01:39 PM
mustangraven's Avatar
I had this happen when it got colder on a explorer I used to own the rubber would contract enough to set off the horn I ended up taking the wheel apart to fix the spring basically stretch it out again and it fixed the problem for me. That was an explorer not and f150 but it could be the same issue in your case its worth a look see took me about half an hour to correct the issue and most of the time was spent figuring out how to dismantle the wheel. Hope this helps.
Len
Old Nov 15, 2007 | 02:40 PM
biglew347's Avatar
Yeah! it's real weird and it was not the alarm. I took the fuse out to get it to stop and tried putting it back in the next day and the horn was still blowing.
Old Nov 15, 2007 | 02:42 PM
biglew347's Avatar
Len
I've got to go out of town today, but when I get back I'll check the spring. Thanks guys for all the help and ideas. Maybe I or we will get it figured out pretty soon. Thanks again, Lewis.
