01 ford f150 4.2 v6 electrical problems
Old Nov 11, 2007 | 07:53 PM
lillibridge's Avatar
I have a 2001 ford f-150 4wd witha 4.2 v-6..Recently I have lost in this order...my cruise control, windshield washers, dome light, windshield wipers and has just recently started hesitation during acceleration. I was told that it was the GEM module which I have just replaced and still none of these are working Please Help??
Old Nov 12, 2007 | 08:53 AM
projectSHO89's Avatar
You've probably left something important out.
Was your original problem attributed to a leaking windshield and water infiltration? If so, you probably will need to also replace your fuse panel under the dash. If so, was the original leaking windshield resealed?
Steve
Old Nov 12, 2007 | 09:20 AM
As far as I know,my windshield has never leaked. So it could be the fuse panel itself? I have just about replaced everything but that and the main computer.
Old Nov 12, 2007 | 11:09 AM
It could be the fuse module.
Leaky windshields have been causing a variety of concerns. Often, replacement of both the fuse panel and the GEM module are required to fix the problem along with resealing the original leak.
Not saying this is your actual fault, however, it's something to investigate carefully.
Steve
Old Nov 12, 2007 | 05:27 PM
I truly appreciate your help! Thanks
