2001 Passenger Window Won't Go Up
Old Oct 30, 2007 | 07:28 AM
98PS190's Avatar
Sorry if this has been asked previously, I couldn't find it.
I have a 2001 Supercab with power windows.
The window went down fine but will not go up. Doesn't matter which switch is used driver or pass
seperated the motor/regulator and hooked the motor back up to the connector and the motor only spins one way (down)
got a new motor and checked it and it does the same thing, only down
I've checked the fuses twice and could not find anything wrong in the cab or under the hood. Swapped the relays around and still only get power down
Guy at Autozone told me it's probably a bad drivers side switch as power starts there, went home and played with the switches
holding the drivers sides switch down, motor spinning hold the pass side up and the motor cuts out. Does the same when the passenger side is held down and the drivers side is held up
Does this mean the switch is working or only partially working?
Does anyone have any troubleshooting ideas?
THanks for your help!
T
