Seat Belt chime
Old Oct 8, 2007 | 04:28 PM
Ricky Bobby's Avatar
Thumbs down Seat Belt chime
anyway to disengage this...annoying as hell to me...i'll put it on when I am ready to put it on stop chiming at me?
Old Oct 8, 2007 | 04:36 PM
Cast'N'Blast's Avatar
Believe it or not there are detailed instructions in your owners manual! It is a ridiculous process of buckling and unbuckling about 10 times. They did not make it easy , which is a way for Ford to escape all liability. I have done it though, so I assure you, it works.
Check your owners manual.
Old Oct 8, 2007 | 04:37 PM
knighj1's Avatar
There is got to be a speaker in the plugged into the fuse box chimming, you may also be able to unplug it at the seatbelt
Old Oct 8, 2007 | 04:39 PM
Shinesintx's Avatar
You "**** excellence," and the great Ricky Bobby cant figure it out? Yeah, "that just happened." Maybe you should just get "jacked up on Mountain Dew," and go at it "like a spider monkey."
Old Oct 8, 2007 | 04:41 PM
Shinesintx's Avatar
On my wifes 03 Exp, you can remove the fuse..Only problem is that the fuse is used for the airbags also.
Old Oct 8, 2007 | 07:53 PM
Thumbs up
Your right I do **** excellence and just to prove it I pissed on the fuse box and I'll be damned if that thing doesnt chime anymore....Shake and Bake
But really thanks for the heads up on the owners manual check...got it turned off finally...that is so annoying to me
