Airbag reset question, help please
I partially took apart the dash on my 1999 F150 to see how to get to the blend door, in the process I removed the passenger side airbag, when I reinstalled everything my airbag light now comes on and stays on. Is there a way to reset the airbag?, I tryed disconnecting the battery but to no luck.
When you get everything put back together right, the light will go off. If it's on, it means there's a problem. There's no such thing as "resetting" a Ford airbag light. You have to fix it, or rip it out.
