Power windows do work when hot
Old Aug 13, 2007 | 05:51 PM
BBerry's Avatar
I have 2000. On sunny summer days when the interior of the cab gets hot, my power windows do not work. After about 5 minutes of running the A/c and cooling down the cab they will work. Seems like there is some thermal switch in-line that is faulty. any ideas?
Old Aug 17, 2007 | 07:51 PM
BBerry's Avatar
accessory delay relay
does anyone know it the windows go throught the accessory delay relay? maybe when hot it is stuck open?
Old Aug 17, 2007 | 10:38 PM
torkum's Avatar
I think your problem is that the rubber molding around the window is sticking to the glass and the motor isn't strong enough to break it free. Try using silicone on the window rubber and your problem should be over.
Old Aug 21, 2007 | 05:20 PM
BBerry's Avatar
I will check that but I did not mention that the radio acts the same way, that is why I was looking for some inline thermal switch resetting after the cab cools down. According to documentation, the window and the radio appear to be on different circuits but both seem to go throught a accessory delay circuit.
