How Do You Disable Automatic Power Locks
Old Jul 29, 2007 | 03:36 PM
pnamarble's Avatar
Is There Any Way To Disable This Annoying Feature On My F-150 Supercrew. Powerlocks Is A Nice Option But It Locking Up Everytime I Put It Drive Is A Pain.need Help!!!!!!!!!!
Old Jul 29, 2007 | 11:11 PM
cwbpro69's Avatar
Check in your owners manual. I am not sure if Ford gives instructions for this on your year model truck, that would be the first place I checked though
On the 04 and up F-150 there was a section giving the steps to do this.
Old Jul 30, 2007 | 12:04 AM
ncranchero's Avatar
Instructions are in my '98 manual.
If you don't have a manual check this out:
http://www.analogstereo.com/pdf/om/f...anual_1997.pdf
Deactivating/activating power door lock/unlock disable feature
All vehicle doors must be closed before beginning the procedure. You
must complete Steps 1–5 within 30 seconds, or the procedure will have
to be repeated. If the procedure needs to be repeated, you must wait a
minimum of 30 seconds to begin again.
1. Turn the ignition to the 3 (ON) position, then press the button
three times.
2. Turn the ignition to the 1 (OFF/LOCK) position, then press the
button three times.
3. Turn the ignition to the 3 (ON) position; the horn will chirp to
indicate the driver configuration mode has been activated.
4. Within five seconds, press the control two times. Note: One horn
chirp should be heard, indicating the system has been disabled.
5. Turn the ignition to the 1 (OFF/LOCK) position to exit programming.
Note: After exiting the driver configuration mode, the horn will chirp
once to indicate a feature has been activated/deactivated.
